Del sol swap problems...
Old Sep 3, 2012 | 07:05 PM
delsolswap93's Avatar
Icon6 Del sol swap problems...
I bought a honda del sol with a motor from an acura integra i think the motor is the b18 or somethig like that and the ecu is for integras 92-94 i think, anyways, my windows dont go up or down, and my tach, spedometer, gas gauge and temp gauge dont work, my dash isnt fried because the brights indicator light come on as well as my battery light, my radio works the heater and fans work, my fuses are good, i havent checked any relays, but i guess my question is, could my problem be a relay, unfinished wiring, cables ect, or maybe the swap isnt compatable with the car and im in trouble, im not sure, will my back window still be able to role down? maybe i didnt provide enough information but its a start, if anyone has any ideas id really appreciate it - Thanks
Old Sep 3, 2012 | 07:17 PM
redm3turbo's Avatar
Default Re: Del sol swap problems...
your first step would be to find out if your running obd0 or obd1, or whats going on..
obv you didn't install the swap, ask whoever you got it from.
you got alot of wiring issues it sounds like. maybe things aren't wired in, maybe unplugged, maybe alot of things. start with finding out exactly what ecu you have, and go from there.
Old Sep 3, 2012 | 07:27 PM
i just went outside to look and its the obd1. the guys story is it stopped working on his way home and is probably a relay, i called a mechanic and asked if thats possible and he said it was, but the question isnt whether or not i should have bought it because its already to late, but its how do i get it working, thanks for the reply
Old Sep 3, 2012 | 09:23 PM
greenteadude's Avatar
your engine or ecu have nothing to do with the gauges or lights not working.. sounds like a wiring issue... check your grounds and connections.
Humantippin
May 4, 2015 02:58 PM
Crims0nSniper
Nov 4, 2009 07:08 PM
BedDeMoN
Jun 27, 2009 12:23 AM
vart
Sep 27, 2005 05:47 AM
