D16Z6 Work
Old Apr 19, 2004 | 01:12 PM
mark7901's Avatar
Default D16Z6 Work
Has anyone successfull put a different head on a d16z6? Such as DOHC? If so, which ones will fit. Also where could I get P&P'd heads? Thanks!
Old Apr 19, 2004 | 07:18 PM
uncle's Avatar
Default Re: D16Z6 Work (mark7901)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mark7901 &raquo;</TD></TR><TR><TD CLASS="quote">Has anyone successfull put a different head on a d16z6? Such as DOHC? If so, which ones will fit. Also where could I get P&P'd heads? Thanks!</TD></TR></TABLE>
Old Apr 20, 2004 | 07:35 AM
mark7901's Avatar
Default Re: D16Z6 Work (uncle)
WOW, uncle....you are filled with information, thanks!
Old Apr 20, 2004 | 08:47 AM
uncle's Avatar
You cannot put a DOHC head on an SOHC block.
Do a simple search and you will find tons of threads about reputable shops that do p&p'd heads.
Old Apr 20, 2004 | 09:08 AM
mark7901's Avatar
Isnt a ZC a dual cam on a SOHC block?
Of course you can find shops that will do P&P with "simple research"....I was wondering if anyone has a shop that they have in mind....
Old Apr 20, 2004 | 11:11 AM
uncle's Avatar
There are two different ZC motors, a single cam and a dual cam.
Portflow is a good reputable shop. If you want an idea on other shops to choose from use the search feature, that is what it is there for.
Old Apr 20, 2004 | 02:02 PM
hondaguyef's Avatar
put a d16y8 head on your z6 block with the y8 head gasket and you will get higher compression (about 1.0 to 1.3 higher). A ZC is a d series yes but the ZC block was meant to have the dohc head on it d16 a6,z6,y8,b2,b7 etc. etc. were not. The ZC is similar looking to the USDM 86-89 integra motors but different on the performance aspect. Look towards Gude for sohc heads and packages. I used to be a mini me guy But I've went to bigger and better things The H series!!!!!!!!
Old Apr 20, 2004 | 02:34 PM
mark7901's Avatar
Default Re: D16Z6 Work (hondaguyef)
Would that new compression level be too high for forced induction?
Old Apr 20, 2004 | 06:41 PM
uncle's Avatar
The z6 head flows better than the y8 head. No the compression level would not be too high using the y8 gasket.
Old Apr 21, 2004 | 02:33 AM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uncle &raquo;</TD></TR><TR><TD CLASS="quote">The z6 head flows better than the y8 head. No the compression level would not be too high using the y8 gasket.</TD></TR></TABLE>
You may be right but a small port to the exuast side of the y8 head and the y8 head would be all around better. The intake ports are the same size on z6 & y8. The y8 head gasket is thinner than the z6 head gasket. He would probably sittin at 10.8:1 - 11.1:1 not exactly sure on the measurement.
Old Apr 21, 2004 | 07:58 AM
uncle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">
You may be right but a small port to the exuast side of the y8 head and the y8 head would be all around better. The intake ports are the same size on z6 & y8. The y8 head gasket is thinner than the z6 head gasket. He would probably sittin at 10.8:1 - 11.1:1 not exactly sure on the measurement.</TD></TR></TABLE>
How did you come up with that compression ratio? Y8 stock compression is like 9.6:1.....
Old Apr 21, 2004 | 12:25 PM
hondaguyef's Avatar
How did you come up with that compression ratio? Y8 stock compression is like 9.6:1.....</TD></TR></TABLE>
Yes 9.6 on the y8 block but, on the z6 block the piston rises higher in the combustion chamber than on the y8 block. The z6 head has a more domed combustion chamber and higher piston rise as the y8 has a more flat combustion chamber and lower piston rise. So if you put the flat combustion chamber on the block with higher piston rise you get higher compression. I mean piston to block deck not stroke when I say rise.
1988HAtCH
Nov 1, 2009 12:27 PM
CivicCR
Jun 18, 2006 08:19 AM
Irish Integra
Mar 9, 2005 10:31 AM
Sassafrass
Sep 24, 2004 03:38 PM
tallblondkid
Aug 2, 2004 10:27 AM
