d15b7 to d16z6
Old Mar 24, 2003 | 12:11 PM
Btothe3rdDegree's Avatar
Default d15b7 to d16z6
hey guys i want to swap my head out on my non vtec for vtec and i was wondering what i would need to do this and how hard is it? thanks guys (yes i searched)
Old Mar 24, 2003 | 01:03 PM
egchan's Avatar
Default Re: d15b7 to d16z6 (Btothe3rdDegree)
its very easy. the head from a z6 or y8 bolts on with no tapping or external oil line like on ls/crvtecs. you just have to decide how to activate vtec and which ecu to use. that will depend on if you go obd1 or stay obd0. there are alot of sites and stuff because i was thinking of doing the same until i got a whole z6 swap. i'll post again after i find the links. also if you have the hf you can't do the mini-me swap because the hf only has 2 valve relief cuts in it. the vtec heads have four.
Old Mar 24, 2003 | 07:03 PM
Default Re: d15b7 to d16z6 (SlickCRX)
its a 92 so it is a odb1, thanks man
Old Mar 25, 2003 | 05:30 AM
what do you mean by hf?
Old Mar 25, 2003 | 06:55 AM
Adriano's Avatar
hf is a crx model (like dx, ex, si...) It's the weakest of them all. Only 8v, not 16v.
Old Mar 25, 2003 | 12:14 PM
Default Re: d15b7 to d16z6 (brryder)
i see anyone else done this? need some help, does the intake mani bolt right up? do i need a new wiring harness? ecu?
Old Mar 26, 2003 | 04:52 AM
anyone?
Old Mar 26, 2003 | 06:59 AM
D16Z6racing's Avatar
All non-VTEC blocks with a VTEC head need an oil line tapped. I'll look for the paper work today.
Ok, can't find it. It's been explained to me about the internals, a VTEC block has oil splashers to properly function. It will work w/o the oil line, but not to it most potential. I'll still try to find all my other info.
[Modified by D16Z6racing, 8:04 AM 3/26/2003]
Old Mar 26, 2003 | 01:04 PM
Default Re: d15b7 to d16z6 (D16Z6racing)
hey d16z6 do greddy turbo kits work on a non vtec engine (d15b7)? or does anybody know if it does will the engine withstand at most 9 psi daily with internal parts? if not which parts need to be replaced? thnaks guys!!
Old Mar 26, 2003 | 03:33 PM
egchan's Avatar
all of the d series manifolds will bolt up. if you go obd 1 you need a conversion harness and ecu. ecu has to be p28, pr3 any vtec ecu except for gsr. i don't know about greddy turbo kits on the old d15b. still looking for the link for you. get back tomorrow.
Old Mar 26, 2003 | 07:51 PM
thanks man!!
Old Mar 27, 2003 | 04:02 AM
egchan's Avatar
go to resource.crx.org and http://www.geocities.com/chacofgs/swap.html
[Modified by SlickCRX, 1:07 PM 3/27/2003]
Old Mar 27, 2003 | 07:13 PM
anybody know if a greddy kit will fit a d15?
CR91X
11
May 12, 2007 04:46 PM
SupraRXZ
Apr 5, 2006 03:55 PM
Amf_crx
Mar 20, 2004 02:52 PM
bhummel
14
Nov 13, 2003 10:48 AM
KamikazeRacinz
12
Apr 9, 2003 07:44 PM
