CTR LSD into a 99-00 SI Trans!! Having Problems
Old Feb 12, 2006 | 09:47 PM
rex_racer728's Avatar
Default CTR LSD into a 99-00 SI Trans!! Having Problems
So from what ive heard its a complete bolt up thing. So i get it all apart and the ring gear from the stock open diff of the 99-00 SI tranny will not go over my LSD. So I have read that you only need a GSR/Type R ring gear for it to the LSD to fit into my trans. Now my question is obviously the GSR/Type R ring gears are bigger than the SI gear, so what is needed to get that GSR/Type R ring gear in my trans!!! Do i shim anything or do I buy a complete ring gear and counter-shaft set-up!Someone help out I am so pissed. All help is appreciated!!
Old Feb 13, 2006 | 06:59 PM
someday's Avatar
Default Re: CTR LSD into a 99-00 SI Trans!! Having Problems (rex_racer728)
i am almost 90% sure you have to get the countershaft as well.
Old Feb 13, 2006 | 08:08 PM
Jaker's Avatar
Don't need the counter shaft. Just need the ring gear with the larger GSR/ITR/CTR bolt pattern. Si and GSR/USDM ITR have the same FD ratio. 4.4:1
Old Feb 13, 2006 | 10:08 PM
Default Re: CTR LSD into a 99-00 SI Trans!! Having Problems (Jaker)
alright cool now the hard part is finding one. Let me know a good place to get one or if you know someone who has one sitting around. I know someone has one. So many people upgrade. Let me know!!
Old Feb 15, 2006 | 03:04 PM
Jaker's Avatar
More parts than you really need, but cheaper than buying new from the dealer:
http://hybrids.jp/forum/showthread.php?t=21945
Golding.racing
Transmission & Drivetrain
11
Apr 23, 2012 07:17 PM
cluelessmale
Dec 1, 2004 09:45 AM
B18C5-EH2
Aug 1, 2004 02:17 PM
justBLZE
Apr 3, 2004 06:41 AM
