ctr better than itr?
Subscribe
May 14, 2002 | 02:34 PM
are there a diff. in the cams if so could you explain... thanks.
Reply 0
May 14, 2002 | 03:19 PM
Re: ctr better than itr? (infamousRRH)
i believe that the CTR intake cam is more agressive than the ITR intake. but the exhaust cams are the same. correct me if i am wrong?
JOE
Reply 0
May 14, 2002 | 05:52 PM
Re: ctr better than itr? (09civichatch)
JOE
You are correct.
Reply 0
May 14, 2002 | 07:03 PM
ctr's and itr's would put out the same power on certain b18c engines
but the ctr's would put more on the b16's something about its piston speeds.
Reply 0
May 14, 2002 | 08:38 PM
Re: ctr better than itr? (BoM)
what about on a ls/vtec bored to 86mm and 12:1 comp.? would it cause the valve to hit the piston?
Reply 0
May 14, 2002 | 09:07 PM
Vtec pistons have bigger valve reliefs, so the will accomidate higher lift cams. You will be fine mike.
Reply 0
May 14, 2002 | 11:32 PM
Re: ctr better than itr? (InfamousRS)
The only difference between ITR and CTR cams is 3 degrees duration on the intake cam.
Reply 0
Subscribe
