CRV, or resleave?
Old Sep 8, 2001 | 08:14 AM
rioninja's Avatar
Default CRV, or resleave?
I've been looking out for a B20 block for my next motor, but i have been contemplating just re-sleeving my B18a block i have in the garage. Any thoughts?
Old Sep 8, 2001 | 10:40 AM
xJ.SLOTHx's Avatar
Default Re: CRV, or resleave? (RioNinja)
resleeve it to a bigger bore....it'll be stronger in the long run anyway. i say resleeve it to a 87mm bore and re work your combustion chambers. put in the right internals and you'll be kicking some ***
Old Sep 8, 2001 | 08:52 PM
paulzy's Avatar
Default Re: CRV, or resleave? (ian)
not with that ls crank, the r/s ratio will be more fucked up than the b20...
Old Sep 9, 2001 | 12:57 AM
Newman's Avatar
New User
Here are some picts to look at and think about what you want to do.....
Regular B18A/B block.... thin walls.... too much carbon = running very rich with Mugen PR3 for LS/VTEC setup
Nice & thick looking... rods & crank are same as B18A/B, but pistons are larger in diameter. I'd say the B20 block is good up to 18 lbs easily with rods & pistons... hell, I boosted 12 lbs w/out any problems with stock internals for awhile
Eitherway, you're looking at paying the same price for either... about $700-$1000 for either a B20 block, or for the price of resleeving the motor.... personally I'd get it resleeved and get rods & pistons, and make that sucker bulletproof
clutch6racerone
Apr 26, 2007 05:34 PM
sprayinBseries
Nov 7, 2006 09:24 AM
pootie.teng
14
Aug 25, 2004 04:50 PM
all motor b20b
May 25, 2004 02:51 PM
