CR-Vtec
Question for the board...........
I was pretty much set on installing a boosted B20B but after doing some reading and limited price checking I was considering going N/A with a CR-Vtec (B20/B16). I've got the block and Transmission for the swap. What I need to know is "What else is required in addition to that to do a sucessful swap?"
Thanks in advance for the help.
B50
B50
B50
CRVtec man it is covered so many times (sorry but here it comes
) do alittle searching. You will come up with some more specific questions which are more likely to get responses from others. Try searching under the archived files using: LSVT, LSVtec, CRVtec, frankenstein, oil feed lines, P28 ecus, LS connecting rods, LS rod bolts, main girdle, Vtec water pump, Vtec oil pump, "goes on and on". Read through some of that info and you should be pretty well set.Good luck on your CRVtec project
Thanks SPLR.................... I'm on the hunt. Just need to know where to look.
"crvtec" "b20vtec" "b20b + vtec"
EDIT: make sure you check the archives!!!
hth,
t..
[Modified by tinkerbell, 11:24 AM 9/4/2002]
blacc_ej1
27
Aug 10, 2009 08:31 AM
