could someone...
This should all come with a changover needed for the swap:
intake manifold
fuel rail w/ injectors
throttle body
throttle cable
exhaust manifold
A pipe
alternator
distributor
ECU
transmission
starter
clutch
pressure plate
flywheel
axles
intermediate shaft
shift linkage
engine mounts
transmission mounts
engine wiring harness
radiator hoses
and all related sensors
intake manifold
throttle body
throttle cable
exhaust manifold
A pipe
alternator
distributor
ECU
transmission
starter
clutch
pressure plate
flywheel
axles
intermediate shaft
shift linkage
engine mounts
transmission mounts
radiator hoses
which of these should the shell have, an which of these should the engine have..or is this all for the engine, or all for the shell..?
[Modified by cIvIc_gSr95, 5:15 AM 10/25/2001]
weakGOODJunKieS.com
16
May 20, 2002 05:15 PM
