B18C Swap into 94 Si
Hey...I'm a noob at swaps although I have a few friends who could come bail me out if I get in a bad way during the project, but after a brief search I didnt find any usefull advice on what all I need other than the JDM engine/tranny/ecu...I know I need axles, shift linkage... but what else? Any advice?
Re: B18C Swap into 94 Si (SuperJon)
- Motor
- Tranny
- ECU
- Axles with Half Shaft
- Shift Linkage
- Motor Mounts
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- All Sensors
- Tranny
- ECU
- Shift Linkage
- Motor Mounts
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- All Sensors
well since ur a n00b you didnt search hard enuff.....there's is this thingie that says recent or archieved......you probably only searched recent.
anyways back to your question, besides wat you listed, you need the shift linkage, GSR upper and low radiator hoses, engine mounts (if they didnt come with it), rear engine mount bracket, all the senors and stuff.....thats all i can think of off the top of my head. also you might want to invest in a fuel pressure regulator and guage.
good luck witht he swap
Re: B18C Swap into 94 Si (eg cookiemonster)
Is the SI Radiator good enough for the GSR? I'm planning on a nice Fluidyne, but I dont have the cash this second.
