Coil On Plug?
Old Mar 18, 2009 | 03:35 AM
The G2 Racer's Avatar
Default Coil On Plug?
I've done some searching and have not turned up too much yet so I figure a post is in order.
I want to convert my B16 to coil on plug, so far the only company that I have found with all the parts is AEM. I would have to use there pencil coils, EPM (replaces the distributor) and ignition box. However, I've not read much about this set up, searching the forums on AEM's site right now.
Opinions on this set up?
Can I run a different EMS with it or am I limited to the AEM EMS?
Also if this is the wrong forum can a mod please move the thread.
Old Mar 18, 2009 | 06:24 PM
Blown90hatcH's Avatar
Default Re: Coil On Plug?
Pencil coils FTL. Go to www.T1racedevelopment.com and check out his options with the CBR coils. Or talk to Jeff at boosted-hybrid.com and he will steer you in the right direction. CBR coils with the M&W Pro-14 is good to go. You can run it with the AEM too.
Old Mar 19, 2009 | 10:37 AM
I don't want to run AEM.
Thanks for the info though.
Old Mar 20, 2009 | 05:36 AM
You don't have to. MoTeC, AEM, FAST, .....pretty much every EMS that will allow you to run COP, you can use the CBRs and M&W.
Old Mar 20, 2009 | 06:21 AM
Jaker's Avatar
You can't run COP with a Honda ECU.
kielcivic
Feb 25, 2011 07:47 AM
061000rr
Jan 9, 2011 06:32 AM
RACEPAK
Jun 27, 2010 03:35 PM
h22 civic
Mar 29, 2010 11:43 PM
