Code 91 solution...
Old Aug 26, 2003 | 02:45 PM
Skyllz's Avatar
Default Code 91 solution...
I am about to drop my 98 GSR in my 96 EK hatch using a 97 Si harness...
So, I will have the dreaded Code 91 most likely has the ECU will be looking for that pressure sensor in the gaz tank.
From there, I know the ecu is looking for a voltage between 0-5V for not throwing a code.
Anyone has that info somewhere so I can rig up 2 resistors so i'll end up with the proper reference voltage between them and not worry about this?
Thanks.
prjctCIVIC
Jun 25, 2008 06:43 PM
mugenboi
Nov 2, 2007 05:12 AM
FuNkDrSpOt
Mar 24, 2007 01:22 AM
EkHatch13
Oct 24, 2002 12:04 PM
