Code 91 solution...
I am about to drop my 98 GSR in my 96 EK hatch using a 97 Si harness...
So, I will have the dreaded Code 91 most likely has the ECU will be looking for that pressure sensor in the gaz tank.
From there, I know the ecu is looking for a voltage between 0-5V for not throwing a code.
Anyone has that info somewhere so I can rig up 2 resistors so i'll end up with the proper reference voltage between them and not worry about this?
Thanks.
Thanks.
