CODE 6? need help!
Old Feb 17, 2002 | 07:17 PM
Nos4R2's Avatar
Default CODE 6? need help!
almost done with my swap. a jap-spec b16 2nd gen into my EK and so far so good. the only problem is i'm still getting a CEL. what could be causing this code 6 to go on?
Old Feb 18, 2002 | 05:46 AM
EE_Chris's Avatar
Default Re: CODE 6? need help! (Nos4R2)
Code 6: ECT - Engine Coolant Temp sensor --> Defective or unplugged.
Do you have it plugged in? This would certainly cause the light to come on.
Do you have a DMM? Take some measurements.
With sensor un-plugged:
@ ~0 Dgr F - should read ~15k ohms
@ ~175 Dgr F - should read ~400 ohms
With sensor plugged in and key 'on':
@ ~0 Dgr F - should read ~4.7V at the ECU
@ ~175 Dgr F - should read ~.80V at the ECU
A quick bit-o-info: The IAT and ECT are the same sensor and thus give similar readings at the same temperature. SO...in the morning, when the car has sat for sometime, you could go out and make these measurements on BOTH sensors and they should be about the same...kind of a sanity check.
Old Feb 18, 2002 | 10:19 AM
WAFFLES's Avatar
Default Re: CODE 6? need help! (EE_Chris)
also just check your connections. i just finished the swap in my car and i also got a 6. check all your connections and grounds, that usually gets overlooked.
Old Feb 18, 2002 | 03:48 PM
Nos4R2's Avatar
i checked the connections, seems to be OK but i'll try playing around with the wires one more time. any other suggestions?
REDREXMANB16
Nov 23, 2006 09:54 PM
Dc_Ek
Aug 9, 2006 08:28 AM
gsr2envy
Nov 7, 2004 03:32 PM
CIVILGSR
Jul 20, 2003 10:42 PM
.brad
Feb 26, 2002 03:30 AM
