Cat problem, any suggestions?
Old Jun 5, 2004 | 11:39 AM
gloryreturns's Avatar
Default Cat problem, any suggestions?
Hey everyone. My catalytic converter is rattling, mostly at idle I think. When I get under the car and push on it, it stops rattling, so I tightened my heat shield hoping that would do it, but no luck. Any advice?
Old Jun 6, 2004 | 10:30 AM
EIT_certified's Avatar
Default Re: Cat problem, any suggestions? (gloryreturns)
hmmm..... this is a tuff one. Oh what else??? take the heatshield off. and if the cat problem persists, call the humane society
Old Jun 6, 2004 | 10:35 AM
hondaZvic's Avatar
Default Re: Cat problem, any suggestions? (sheemo3)
yeah... take heat shield off... make sure all the bolts are tight on both sides... and if u gotta o2 sensor in it.. make sure its tight.
Old Jun 7, 2004 | 08:25 AM
ek99's Avatar
Default Re: Cat problem, any suggestions? (hondaZvic)
Sounds like the inside of your cat is busted. It happened to me before, a big chunk broke inside and it was bouncing around and rattling. Time for a new cat.
Old Jun 7, 2004 | 03:30 PM
hondaZvic's Avatar
Default Re: Cat problem, any suggestions? (ek99)
or if a piece did break off inside... u could just gut it... i found a hydraulic jack handle works good. thats what i did... nothing rattling inside mine.
Old Jun 7, 2004 | 08:20 PM
If I gut it out will I throw a code? I have an O2 sensor on my cat... is a stock Honda cat better or an aftermarket. I'm planning on kepping my engine pretty well stock...
Old Jun 8, 2004 | 12:30 PM
what's the point of gutting the cat???
Old Jun 8, 2004 | 12:47 PM
Adam.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gloryreturns &raquo;</TD></TR><TR><TD CLASS="quote">If I gut it out will I throw a code? I have an O2 sensor on my cat... is a stock Honda cat better or an aftermarket. I'm planning on kepping my engine pretty well stock...</TD></TR></TABLE>
Most aftermarket "cats" are essentially metal tubes. Few will pass emissions, the rest will not. From what I hear stock cats are ******* expensive.
Old Jun 8, 2004 | 03:07 PM
hondaZvic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheemo3 &raquo;</TD></TR><TR><TD CLASS="quote">what's the point of gutting the cat???</TD></TR></TABLE>
well..
-it gave me something to do when i was bored one day...
-makes ur car louder (usually)
-makes ur exhaust less restrictive
-its illegal (i like to break the rules )
Old Jun 9, 2004 | 02:12 AM
ek99's Avatar
Just get a used oem cat. They go for about $80. If you are obd2, you have no choice. A straight pipe is great, but gutting the cat is not. If you gut the cat, your car will be louder and will not flow as well as a straight pipe.
Old Jun 9, 2004 | 07:32 PM
Lord Helmet's Avatar
Default Re: Cat problem, any suggestions? (DarkKnight[DMD])
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkKnight[DMD &raquo;</TD></TR><TR><TD CLASS="quote">]
Most aftermarket "cats" are essentially metal tubes. Few will pass emissions, the rest will not. From what I hear stock cats are ******* expensive.</TD></TR></TABLE>
$800.00 to be exact. this price is for a 95' civic ex at local honda stealership.
Old Jun 10, 2004 | 08:09 AM
ek99's Avatar
Default Re: Cat problem, any suggestions? (sleeperciv)
I bought a slightly used one for $80 (obd2). My friend bought one for $50(obd1). We got them from the Recycler.
Old Jun 12, 2004 | 07:55 PM
I took the cat off and had some sort of metal cylinder thing in it... I have no Idea what it is or where it came from, but problem solved, thanks everyone...
mrspeedy69
15
Jun 13, 2009 06:09 PM
PowerLeg
Oct 17, 2008 09:01 PM
The_'Lude-Dizzle
Dec 16, 2006 06:16 PM
silver ek
Feb 9, 2004 10:05 PM
AWDSOME
Dec 28, 2001 05:26 PM
