cat converter question
Old 02-27-2003, 11:30 AM
95hybridcivic's Avatar
Default cat converter question
I have had my B18C swap in for a little over a year now and I have noticed that I am getting some blueish black smoke out of my exhaust at high rpm (above 5000) I do not have a cat installed could this be the cause of it or could it be valve seals. I did a compression test last weekend and the cylinders were 245psi across the board so i think my rings are ok. I am also getting an o2 sensor code could this be because i am not using a cat. Once the engine is warmed up and you shut the car off and turn it back on the check light goes away. Thanks for any info you can give me
Old 03-04-2003, 10:50 PM
IN VTEC's Avatar
Default Re: cat converter question (95hybridcivic)
With those compression numbers, cylinder sealing sounds just fine. Valve seals it is then.
I'm assuming it's only using one oxygen sensor. The o2 sensor code isn't from not using a cat. The sensor is before the cat, and the cat shouldn't have any bearing on the health of the sensor. I say pull it out (22mm open-end wrench) and look at it. Gently clean it with a tooth brush and some carb cleaner if it looks fouled/caked. Replace if necessary. Check all wiring continuity with wiggling regardless.
strider380
04-30-2011 05:56 PM
janek
06-25-2010 02:16 PM
janek
06-25-2010 11:39 AM
Atomic1
04-04-2010 04:06 PM
halfNhalf-83
11-20-2003 11:12 PM
Quick Reply: cat converter question
