Car running real lean help!!!!!!!
Old Apr 22, 2003 | 06:48 PM
JDM EG2's Avatar
Default Car running real lean help!!!!!!!
I just put my a/f guage on my all motor car in the sig and when @ WOT it only lights up the red (lean area) and while cruising sometimes doesn't even light up @ all. I hooked it up @ the ecu to D14 oxygen signal wire which leads to the white wire on O2 sensor. Is this hooked up right?????
All I have is high compression. Should it really be this lean. For fuel I only have a chipped ecu and a stock gs-r fuel pump. Also my fuel pressure is @ 40psi.
Can I add a Fuel pressure regulator and start turning up the fuel pressure till it goes to rich @ WOT? Will this work???
The only other thing would be injectors and aftermarket fuel pump, but don't have the funds for that right now.
Old Apr 22, 2003 | 06:53 PM
poison's Avatar
Default Re: Car running real lean help!!!!!!! (TurboB16Coupe)
what compression are you runnin?
I would run a lot more than 40 psi at WOT. Take off the vacuum hose and raise your fuel pressure (assuming you have an adjustable fpr) and raise that to 48ish PSI w/ the vacuum line.
I would also check your ignition timing and set it at 0.
HTH.
Old Apr 22, 2003 | 07:00 PM
JDM EG2's Avatar
Default Re: Car running real lean help!!!!!!! (poison)
I have CTR pistons and in a gs-r motor is 12.3:1 compression, plus the head was slightly milled so I guess around 12.5:1. I don't know for sure, due to don't know how much was exactly taken off the head as I bought the motor how it is now.
My FPR screw is stripped and I can't adjust it any higher than 40psi. I have to get a new B&M top.
I might try to put a clamp on the return line to try and raise the pressure a little.
Is my wiring for the guage right?????
Old Apr 23, 2003 | 07:53 AM
88_SC_CRX_Si's Avatar
New User
Have you pulled the plugs and check their color. That will tell you if your really running lean, or if it's just the gauge.
When was the last time the O2 sensor was changed...?
Old Apr 23, 2003 | 04:14 PM
JDM EG2's Avatar
Default Re: Car running real lean help!!!!!!! (88_SC_CRX_Si)
I just recently wired it up. I'm gonna change the plugs out this weekend also.
I added a fpr and turned it to 48psi and still the same no difference.
If I put the car in 5th gear @ like 35-40 mph and floor it you can hear the valves pinging.
Does anyone have any suggestions?
Old Apr 23, 2003 | 05:37 PM
Gravy's Avatar
how do valves ping????? last time i checked valves only tap.
Modified by GRTechnologies at 11:12 PM 4/23/2003
Old Apr 23, 2003 | 08:09 PM
JDM EG2's Avatar
Default Re: Car running real lean help!!!!!!! (GRTechnologies)
U know what I mean.
Old Apr 23, 2003 | 11:25 PM
samiam's Avatar
Yup it's pinging.. try retard timing a few degrees. or you cuold try octane boost...HTH
Old Apr 24, 2003 | 10:40 AM
sleeper4dr's Avatar
Default Re: Car running real lean help!!!!!!! (samiam)
or you could try running NGK BRK7E spark plugs to cool down your combustion a bit.
Old Apr 24, 2003 | 12:28 PM
Cltchbrnr's Avatar
If its pinging you need to definitely do something. However what air/fuel meter are you running? Stock O2 sensor? If so get rid of it and get real one or go to dyno. The ones that hook to a stock O2 other than the VX five wire don't work worth anything. Those sensors are meant to read at stoich only. You want to be about a full point below stoich. Good luck.
Old Apr 24, 2003 | 01:25 PM
JDM EG2's Avatar
Default Re: Car running real lean help!!!!!!! (Cltchbrnr)
I will be dynoing it this Saturday @ Cartek Tuning @ there dyno day I'll get the A/f ratio then.
Old Apr 26, 2003 | 06:38 PM
JDM EG2's Avatar
Got it dynoed. The dynoed a/f ratio showed different than the a/f gauge. I was running to rich @ 48 psi with stock fuel pump and even @ 40 psi I was still runnig a little to rich on the dyno. My a/f gauge still showed lean though.
Here is the post with my dyno #'s: https://honda-tech.com/zerothread?id=487812
jman86
Nov 7, 2024 12:19 PM
s032105k
11
Apr 14, 2011 08:01 PM
jaredvabeach
Aug 6, 2008 07:38 PM
onefstek
Dec 5, 2005 10:29 PM
baby50
Oct 11, 2005 07:50 AM
