Can somone please verify effective compression
Old Apr 19, 2013 | 06:38 AM
THC07's Avatar
Default Can somone please verify effective compression
F23a1 block, crank, rods, H22a4 pistons (are the F23a pistons floating?) H22 head
No milling, .030 H Gasket.
Im getting 11.35 compression. anyone able to verify?
TIA
Old Apr 19, 2013 | 06:53 AM
honda_12V's Avatar
Default Re: Can somone please verify effective compression
Hey,
I get 11.47:1
But the h22 pistons will be out of the hole 1mm and u would need to rebore the block to 87mm as stock bore on f23 is 86mm
everything else should match up.
Old Apr 19, 2013 | 07:00 AM
THC07's Avatar
awesome! thank you.
did you calc .026 gasket or .030?
Old Apr 19, 2013 | 07:03 AM
honda_12V's Avatar
0.026.
I read leave the gasket oem when it crushes it gives 0.026
IMO you would need aftermarket cam gears to work out the allignment of cams to crank.
Regards
Dango
Jun 14, 2012 09:56 PM
jdm-addik
Mar 6, 2012 03:39 PM
h22bluelude
Oct 1, 2011 02:10 PM
Jago
Jun 29, 2006 02:31 PM
kazino42
May 22, 2005 02:41 PM
