can i use this map sensor? NEED HELP ASAP!
Old Nov 4, 2004 | 01:51 PM
DeadVet's Avatar
Default can i use this map sensor? NEED HELP ASAP!
I have everything to swap a d16z6 into my 92 dx except the map sensor on my dx motor is mounted on the firewall and the d16z6 map sensor is supposed to mounted on the throttle body. Can i just make a block off plate to cover the opening on the throttle body and tee off another vaccum line so i can use the dx map sensor? I dont have a d16z6 map sensor and need to put this motor in tomorrow. Thanks guys
Old Nov 4, 2004 | 04:08 PM
DeadVet's Avatar
Default Re: can i use this map sensor? NEED HELP ASAP! (92GuttedHatch)
BUMP BUMP BUMP
Old Nov 4, 2004 | 06:15 PM
pb16b's Avatar
yes you can.
Old Nov 7, 2004 | 12:27 PM
b18ccivics's Avatar
instead of making a block of plate switch throttle bodies
Brumeh
Jun 7, 2013 06:30 PM
Mikes2000civicsi
Jun 4, 2011 09:02 PM
A90Civic
Jun 9, 2009 01:36 PM
SVOboy
Mar 26, 2006 11:48 AM
DeadVet
Nov 5, 2004 05:22 AM
