Cables for the H22a
Will the shifting cables from a 89 or 90 prelude work instead of the 93-96 cables that are traditionally used when swapping motors. I plan to put an H22a in my eg and the only cables I could find from a prelude (in my area) are on a older modle.
Thanks
Thanks
Ok...you can use any 90-93 accord cables (i say 90-93 because there are tons of them in junkyard). Or 92-96 Prelude cables, and a lot of things can be swapped with preludes and accords. Just use the whole accord shifter assembly it'll work.
You don't need the boot.
All you really need is the bottom bracket, the cables, and the shifter arm (attached to the bottom bracket).
On top of that you'll need 4 of the U clamp things. Forgot what they're called but two go on the shifter assembly, and two on the tranny. You guys know what I'm talkin about.
sounds good but I gotta work around 5:00 or 6. I guess I forgot about the accord when I called and was focused on prelude. I just called U-Fix-It-Honda and they have The intermediate shaft and entire Linkage I need, but I 'll see what Gene's has first before I order it.
Thanks for all the info guys
pcguy760
Oct 14, 2013 02:32 PM
cpforyou
Dec 5, 2005 12:26 AM
Does the prelude H22a shift lever assembly have shorter throws than the 90-93 Accord shift lever ass
se93
May 8, 2002 09:25 AM
