built ls or gsr??
Old May 18, 2002 | 02:12 PM
1hotintegra's Avatar
Default built ls or gsr??
i have a 94 ls integra. i have 130k on the car now. Im goin to need to do something with the engine soon. i was wondering what hp i could get out of my ls if i rebuilt it with high compression pistons, maybe bore it out, cams etc. i really dont feel like goin through the hassel of finding and dropping in a gsr engine. anybody have a built ls tell me what u have and how much u have spent on it. any thoughts and comments will help! thanks!!
Old May 18, 2002 | 03:00 PM
DLB1994's Avatar
Default Re: built ls or gsr?? (1hotintegra)
rebulid with ls/vtec and high compression pistons
Old May 18, 2002 | 04:05 PM
Default Re: built ls or gsr?? (DLB1994)
i dont really want to do the ls/vtec. i've heard too many things that go wrong with them. id reather build up my ls and have it be reliable
Old May 18, 2002 | 05:06 PM
DLB1994's Avatar
whats your hp or 1/4 mile goal
Old May 19, 2002 | 12:08 AM
GokuSSJ4's Avatar
imo is not worth it building ls (all motor ) either go turbo or gsr
friend of mine had way to many problems with his ls (n/a) and spend way to much $$ and at the end went b16
Old May 19, 2002 | 01:56 PM
pg_thao's Avatar
go all motor ls.. thats my opinion or ls turbo..
Old May 19, 2002 | 01:57 PM
B_CRUZ!'s Avatar
rebuild the LS and then turbo or get a GS-R long block and then go from there.
Old May 19, 2002 | 02:38 PM
Default Re: built ls or gsr?? (B_Cruz)
the only reason i want to build up my ls is becasue i have 130k miles and want to rebuild it so i might as well build it up to go faster. i really dont want to search for a gsr then have to worry about the tranny and v-tec wiring etc.
Old May 19, 2002 | 02:47 PM
B_CRUZ!'s Avatar
you can reuse your LS tranny but the gearing is too wide. as for the wiring, it really isn't that hard. all you have to do is add 2 wires i believe if you have a LS. i wired my gs-r swap into a 94 CX civic and all i added was 3 wires. Knock sensor, VTEC solenoid and the vtec pressure switch. i think LS's came with the knock sensor though but i am not sure.
Old May 19, 2002 | 04:51 PM
anyone know where i could get just the gsr engine from for a good price. anyone have any problems or know of any swaping a gsr in an ls?
Old May 20, 2002 | 05:38 AM
phatintegra's Avatar
ttt
Old May 20, 2002 | 07:42 AM
Kataku2K3's Avatar
Default Re: built ls or gsr?? (phatintegra)
yea the i would go with a GSR if you don't want to do LSVTEC.
Old May 20, 2002 | 04:54 PM
Default Re: built ls or gsr?? (JDMspecEG6)
1hotintegra
May 30, 2002 02:55 PM
Cyrio
May 24, 2002 10:30 PM
1hotintegra
May 22, 2002 03:28 PM
-=SpOon=-
Feb 28, 2002 02:27 PM
xsnrgsr
Aug 13, 2001 01:42 PM
