Block questions
Old May 28, 2001 | 07:07 PM
555R's Avatar
Default Block questions
ok me being somewhat new to hybridizing and stuff
i need to know if the B18C1 and b18C5 blocks are identical.
ie- i plan on building a bottom end and have access to a C5 block to swap into instead of building the C1 bottom end
are they identical if i put a 98 GSR head on the C5 block in terms of deck height, compression, all specs?
Help me out here
Old May 28, 2001 | 09:08 PM
HXMan's Avatar
Default Re: Block questions (555R)
Should be the same except for higher compression pistons and maybe different rods?
Old May 29, 2001 | 07:25 AM
GSRedline's Avatar
New User
Default Re: Block questions (HXMan)
funny you ask this question. I just put together a ITR block w/GSR head.
C5 block= P73-AO pistons, micropolished crank, stronger rods, oil cooler
C1 block72-AO pistons, etc, etc, etc
GSR head on C5 block gets you 10.8-10.9-ish CR.....everything bolts up perfectly, no drama. If you do this get a Mugen head gasket, increases CR by .4. So you'll be at 11.2-11.3-ish CR. My motor feels strong as hell. I have 72 miles so far on the new block.
[Modified by GSRedline, 8:27 AM 5/29/2001]
jerryscherry
K Series
Apr 5, 2010 12:25 AM
lil98civi
Jun 17, 2008 06:41 AM
on-the-line
Feb 13, 2008 04:48 AM
ORANGE EF
May 25, 2006 02:21 PM
captainjdog
Nov 17, 2005 10:47 PM
