B20z throttle body problem
Old Aug 17, 2002 | 02:26 PM
b20guy's Avatar
Default B20z throttle body problem
Ok I just realized that the b20z throttle body pulls the throttle cable from the passenger side as opposed to the LS which pulls from the driver side I had bought an Si throttle cable before I realized this. What can I do to make this work? CRV throttle cable? or change out the spring and throttle bracket?
Old Aug 17, 2002 | 02:41 PM
daver's Avatar
Default Re: B20z throttle body problem (b20guy)
you sure about that mr. my b20 one doesn't. It should turn (open) counter-clockwise and the cable fitment should be at about 10-11o'clock.
d
Old Aug 17, 2002 | 04:10 PM
b20guy's Avatar
Default Re: B20z throttle body problem (daver)
mine is at 4 o'clock. yes, counter-clockwise. i have a throttle stay bracket mounted on the throttle body up high (about 2 inches above the TB)
Old Aug 18, 2002 | 03:57 PM
tinkerbell's Avatar
b20guy, was it the big manifold or hte little one?
the big one is what i got - and it is a weird setup...very unconventional.
if you want to use it, you will have to create a bracket that allows you to do so.
make sure it is minimum 1.5mm steel or 2mm aluminium, it souldnt be too hard, it will save you having to buy more new parts and you can use the Si cable...
hth,
t..
PS here is a template TJ has used as a bracket... http://tjshondas.20m.com/cgi-bin/i/b16a/tcable.jpg
Old Aug 18, 2002 | 04:34 PM
b20guy's Avatar
Default Re: B20z throttle body problem (tinkerbell)
Its the LS type one with the hole on top for the resonator box. You must have the giraffe style eh?
Yeah I'm thinking either use the CRV throttle cable or switch out the tb pulley and spring or fab something.
and thanks, i might cut some metal now that you mention it.
[Modified by b20guy, 7:35 PM 8/18/2002]
wade
Mar 18, 2009 01:14 PM
neo_
Feb 15, 2009 11:10 AM
hamst3r3x
Dec 10, 2007 09:41 PM
Chango_racing
Jul 13, 2005 03:31 PM
NatrualAsp VTEC
Sep 17, 2003 05:19 AM
