B20help please!!!
Hey guys so I have a 99 ek with a ob2b to obd1 jumper harness running to a obd1P75 and my car has recently had a 98 crv b20b4 engine into it ran fine a month ago when I received motor but now I've swapped it into my car and it's idling is horrible it idles fine while cold and warming up I've changed iacv twice with known working ones and no change checked for vacuum leaks nothing bought two ect sensors and put new plugs on ECT plug thinking maybe it was bad has new plugs and wires new intake gasket rebuilt stock injectors ls intake throttle body cable and fuel rail new thermostat bled cooling system three times on stands for 35 minutes until fan kicked on twice each time no change timing is dead on checked twice valves r within tolerances I'm so lost the car will idle good warming up but as soon as it is almost halfway on gauge the car will just completely die but will start right back up np but here's the kicker I'll turn it back then idles super low barely idling like 300rpm and I'll unplug ect and it'll idle up to 750 and stay around there and flu tuate a little like 825 to 750 then I can plug ect back in and it'll continue to idle that same way please help I'm out of thoughts and I'm ready to rip my hair out lol thank u so much guys!
Has the tps been messed with at all? Perhaps the tps thinks its being given more throttle than it is so when the car warms up it is getting enough gas to run but once its warm and it closes some of the air and it cant stay running because it thinks it has more air than it does. Maybe the map sensor? The tps and the map swap right from a d16. I hope you figure it out man
Theres fluctuation when warmed up only and usually it's just 750 to 150 then back up a couple times then dies when it does it the second time I have a video of what it's doin but I don't know how if show u lol
Hondas do this thing where if it thinks its idleing too high it cuts fuel at the injectors then it thinks its going to die so it lets the injectors do their thing then cycles like that. This normally happens from a vacuum leak somewhere. If you take the intake piping off and start it and put your hand over the throttle body to smother it does it die? It should and if it doesnt then it has a leak somewhere. But usually a vacuum leak causes high idle followed by low but you have normal idle followed by really low
I assume but can't confirm cause I have to order the fitting they make to attach a gauge to it I don't have fuel in oil so I know diaphram isn't leaking but I unhooked cacuum from regulator to Max out pressure and no change and I also shot a shot of carb cleaner in the throttle body when it was getting ready to stall and it instantly killed it so I'm not sure if that helps or not lol
Carb cleaner would kill the motor. Does it rev up good when you put your foot on the gas? Does it bog and die? Does it go up and redline at like 4k?
I can drive this car down the road with np until I stop then it stalls and dies it red lines at like 6k I had it at 90 with no probs at all drives great
ChefBoyardee
Nov 19, 2007 08:41 AM
