B20b head on b18b block
Old Apr 17, 2002 | 03:05 PM
275Performance's Avatar
Default B20b head on b18b block
I was planning on poping a b20b head on b18b block. Everything should be the same right? Just wanted to double check that an LS head part will fit the b20 head.
Old Apr 17, 2002 | 05:35 PM
StorminMatt's Avatar
Default Re: B20b head on b18b block (drivingchallenge)
The head is actually a different part number. But I am not sure what the differences are. In any case, it will work. But keep in mind that the cams are different. They don;t seem to be as aggressive as B18B cams.
Old Apr 17, 2002 | 05:52 PM
Default Re: B20b head on b18b block (StorminMatt)
I had heard of people using LS cams in b20? Does this not really work? Anyone know? I had heard all b18b head internals fit b20 head.
Old Apr 17, 2002 | 07:54 PM
JalopySiR's Avatar
Hey, It's SonOFTOO, from the resource... are they different part numbers because the b18 is technically an "ACURA" motor, while the B20 is a "HONDA" motor. I specify this because niether is swapped over from one to the other, and I thought (everyone says) that the heads are IDENTICAL...I mean they look identical...Oh, and specs on cams? I have heard again that those are the same. 99+? cams being more aggressive in the B18? any specs part numbers on these? Take it easy Matt, see you around...
Old Apr 17, 2002 | 07:59 PM
allmtr's Avatar
isnt the b20 intake manifold too big to fit under our hood. thats just what i hear.?????
Old Apr 18, 2002 | 01:12 AM
customx_'s Avatar
New User
relatively, b18b and b20 heads are the same. only when it comes to the block, its different.
Old Apr 18, 2002 | 05:17 AM
DevinW's Avatar
Default Re: B20b head on b18b block (allmtr)
Yeha the b20 intake manifold is too big to fit under the hood of an eg. Swap it for an LS manifold or a skunk2
Old Apr 18, 2002 | 06:27 AM
Default Re: B20b head on b18b block (DevinW)
Yeah the intake manifold won't fit under any hood here but CR-V. I was just wondering how well these would work. I already have the b20 head form my under construction B20/vtec project. I was thinking about buying a LS short block and putting the B20 head on it. I was just wondering about pistion clearance, and it I could use things such a aftermarket LS camshafts, gears, valves, etc on my b20b head, I just didn't know how much they were alike, or if they we exact as some people said.
Old Apr 18, 2002 | 09:15 AM
memphiss13's Avatar
i believe they are the same, b/c i have heard of people putting the LS head on the b20 block. i don't know how true it is, but i read that the LS head is actually better. so your theory about the cams being different might be right.
Old Apr 20, 2002 | 11:31 PM
LS-G's Avatar
Default Re: B20b head on b18b block (rookie2nr)
i bought a b20 throttle body from a guy who had a b20 and b18 head, sitting in his garage. i visually compared the two and noticed 2 differences. oil hole size on the b20 is bigger. also dowel pins (locating pin) were at different positions but same locations.
Old Apr 22, 2002 | 06:45 AM
Default Re: B20b head on b18b block (LS-G)
My main thing is to find out what LS aftermarket can I use in the b20b head. Cams, Valve train, etc. I fit the head to the block and its perfect.
Jillianbowman87
16
Oct 17, 2011 01:24 PM
juicedricer
19
Jan 19, 2011 08:37 PM
bambam
Apr 6, 2004 08:54 AM
Chuji
Sep 6, 2001 05:25 PM
