B20b in ek hatch wiring problems obd2
Old 05-08-2016, 01:34 PM
Cfisch619's Avatar
Default B20b in ek hatch wiring problems obd2
Hey guys, so I got my b20b in finally and need help wiring, looks as if i need to extend some wires to get them to fit, and my distributor cap plug on the b20b doesnt fit on the stock 97 dx harness. Do i need to buy an integra dizzy cap or what. I'm super ancy and want to hit the mountains help me please!
Old 05-08-2016, 06:42 PM
Cfisch619's Avatar
Default Re: B20b in ek hatch wiring problems obd2
i belive i have to get a new distributor since i just matched up the integra ls obd2 wiring harness i have lieing around any thoughts though, has anyone came across this problem?
Old 05-08-2016, 09:43 PM
DVDr's Avatar
snap a picture of your b20b distributor.
it might be an obd2b ( if jdm ), depending on dizzy you have you need to swap the connector .
you will be able to use the dizzy.
Old 05-08-2016, 09:44 PM
DVDr's Avatar
this image might help
Old 05-09-2016, 07:10 AM
Cfisch619's Avatar
Here they are. The distributor im using is from the jdm b20b.
Old 05-10-2016, 10:42 AM
DVDr's Avatar
Easy fix,
decide what connector you want to use ( either stick to obd2a from your chassi and cut off the connector from distributor and solder on the coonector from chassi side, or stick to the distributor and swap chassi connector )
I suggest cutting the connector off the distributor and soldering/connecting the male part from chassi.
greddy2smoke
07-16-2007 08:52 AM
greddy2smoke
07-16-2007 08:50 AM
PNPFLIPPED
06-19-2006 07:55 PM
Quick Reply: B20b in ek hatch wiring problems obd2
