B20 VTEC, will the valves clear?
Old Feb 13, 2002 | 02:29 AM
Ri5e's Avatar
Default B20 VTEC, will the valves clear?
Ok, I got a question. If I drop a B16 Head on the B20B motor, will the valves have enough clearance? Or do I need to get aftermarket Pistons?
Old Feb 13, 2002 | 05:25 AM
Trey's Avatar
25 Year Member
Default Re: B20 VTEC, will the valves clear? (BG Boost)
After market piston is a better way to go but you can take a dremel and extend the valve reliefs for the intake valves. Not that hard. Just measure the diameter of the valves and match it on the piston. Take your time......
Old Feb 13, 2002 | 07:03 AM
rainforest's Avatar
Default Re: B20 VTEC, will the valves clear? (Trey)
with stock valve relifes its 3 degrees you cant retard or advance. thats when you have a problem. but stock is good.
quick Dick
Mar 30, 2008 02:00 PM
JOeiROck
Feb 19, 2008 12:28 AM
Han Solo
Mar 15, 2006 10:26 PM
FearXxConduct
Mar 30, 2004 05:53 PM
Turbohatch
Mar 15, 2002 05:29 AM
