B20/VTEC swap problem
Old Nov 24, 2005 | 05:19 PM
timisyourfriend's Avatar
Default B20/VTEC swap problem
it can start sometimes, but it will sputter. at times it can be difficult to have a constant idle, but oddly enough it is constant at times. When it is constant and normal at idle, when I rev it, it will do the same sputter from 2k rpm and on. Eventually the engine will die out each time, and I will have start it again. It's not easy to start if I may also add. But basically sputtering is my main problem.
It seems like a fuel issue, but I've checked fuel, the entire system seems good... constant fuel pressure, etc.
Ignition, the spark wires are good and the plugs are good. I am waiting to get a new distributor, but if that doesn't solve it, I am friggin clueless as to what it may be.
No codes being thrown... and another problem is that sometimes when I rev, the speedometer will go up. 0-20mph and then that's it. Random spurts.
I am running a stock P28.
Any ideas or suggestions?
Old Feb 28, 2006 | 07:14 AM
K20Ej1's Avatar
Default Re: B20/VTEC swap problem (JZPerformance)
i have the same problem...it doesnt like to start and its like i have a redline at 6700 fuel and spark are good...sputters the same...sry not tryin to steal ur post...but i have the same problem...
xlusiveracer
Apr 2, 2018 03:55 PM
CameronEF9
Jan 24, 2009 02:45 PM
Thrillahbeeh
Feb 23, 2008 05:57 PM
Vtec_Dude
Feb 17, 2008 06:38 PM
jspek29
10
Oct 20, 2006 06:44 AM
