b20 vtec which power steering bracket?
i have a b20z in my 96 civic, b20s use the same as d series civic power steering pump.
working fine right now.
i have a b16 head to go on now. what bracket will i need, and will i need to switch to a different pump? b16 si part number is differnet from crv
and the brackets appear different as well.
thanks guys
thanks guys
hey man,
Im in the same boat as you are.
The b16 upper bracket will work, apparently.
Also, if you cant find that, use the integra type r upper bracket, as they are the same as the b16 bracket.
At acura the part number for the upper bracket on a type r is:
56997-p73-000 its roughly 100 bucks.
Goodluck.
Goodluck.
ended up all b16 brackets, lower and upper
and you HAVE TO use a 99-00 si pump because 96+sohc and 99-00 si pumps have the same pressure hose bolt pattern
