B18c5 In A Crx
Old 04-16-2004, 09:31 AM
FastAllmotorLsVtec
Guest
Posts: n/a
Default B18c5 In A Crx
whats up i am doing a project next month and going with b18c5 can someone post the steps or links to swapping out an engine and back in.I use 2 have it but got a new comp
Old 04-16-2004, 09:42 AM
tiresmoke's Avatar
Default Re: B18c5 In A Crx (CrxStreetRacer)
Do a Honda-Tech search and you will get all the info you need. the search H-t search is a great tool. If you do a search and don't find anything then repost and you won't get flamed like you may get flamed now. hope that helps
Old 04-16-2004, 04:24 PM
FastAllmotorLsVtec
Guest
Posts: n/a
Default Re: B18c5 In A Crx (tiresmoke)
ive searched and found no steps!
Old 04-16-2004, 10:27 PM
zensoku207's Avatar
You didn't search hard enough dude.
Check out hybrid.honda-perf.org, and look in the swap section. Maybe that'll help some.
hth
Old 04-17-2004, 08:58 AM
FastAllmotorLsVtec
Guest
Posts: n/a
Default Re: (zensoku207)
site doesnt work.....
Old 04-17-2004, 11:46 AM
zensoku207's Avatar
try http://tech.hybridgarage.com/
Its under the tech library section
Draggin99Si
11
05-31-2013 04:31 AM
Panda hatch
08-01-2007 01:43 PM
austrian type-R
04-07-2002 10:48 AM
Quick Reply: B18c5 In A Crx
