B18c1 swap mount bracket help needed
ok,
I just got a 98' b18c1 to swap into my 98 honda civic ex.
the swap came with:
Motor
Tranny
Shiftlinkage
axels
p72 ecu
ok I found out I could use my
wire harness from my ex civic since it has vtec and is obd2 already, it's just plu and play.
and I ordered the Driver side mount bracket from the 99-00 Si (it's on the way)
Now I found out in a few sites that I need a few more mounts/brackets, for this swap.
the 96 del Sol AC bracket if I want A/, and
Rear Tranny mount from the 99-00 Si
maybe someone can shed some light on this issue do I need the other two parts or not ?
I coud also use any advie anyone can offer about this swap. this is my first one and I want it to run smoothly. and yes I already have the helms manual.
thanks,
Jeff
the swap came with:
Motor
Tranny
Shiftlinkage
axels
p72 ecu
thanks,
Jeff
swoyEKr.
Mar 23, 2005 05:06 PM
daver
Sep 2, 2003 01:23 PM
