b18c1 problems please help!!!!!!!!!!!!!
ok i had a post on here about a month ago and didnt end up getting all the information i need so here is a lil breakdown!!!!!!!
i have a 96 civic ex i swapped in a 96 gsr engine and tranny
i had to use the 96 civic ex harness extended wires where needed the car runs and drives......but the car runs horrible!!!!!!!!!! there are 2 sensors that are not on the ex which i understand that i have to use from the gsr which is cool ...... now comes the fun part i dont know where to connect them if i run straight wires to the ecu or tap into my 96 civic ex harness?????? i am not throwing anycodes!!!!!!!!! using a obd 2 scanner????? i also have searched this for the past month i need this car fixed asap!!!!! i also saw that i need to change pin a12 to a14 any help will be greatly appricated........so if there is anyone that has completed this swap and ran into these problems ...... please help!!!!!!!! thanx in advance
u have to let us know what ecu u are using that determines if u have to do the a12 to 14 fix. yes u are supposed to use all the sensors from the gsr. since u have no idea what they are how are we just supposed to know? i suggest posting some pictures of your problem so we know what u are talking about or at least tell us what the sensors are.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eghatch4sale »</TD></TR><TR><TD CLASS="quote">there are 2 sensors that are not on the ex which i understand that i have to use from the gsr which is cool ...... now comes the fun part i dont know where to connect them if i run straight wires to the ecu or tap into my 96 civic ex harness?????? </TD></TR></TABLE> come on dude. if u put the motor in urself u should be smart enough to ask a better question.
im running the 0bd2a gsr computer!!!! and as far as the sensors go i do not know what the are called and i do not have a camera im sure that someone on this board has ran into thse problems......i just need some one to help
Dravenm4
Dec 5, 2008 06:36 PM
