b18c1 -> EK o2 sensor question
Old Apr 17, 2004 | 08:10 PM
vultron's Avatar
Default b18c1 -> EK o2 sensor question
ok i just swapped a 97 b18c1 into my 96 honda EX using the 96 ex wire harness and the 97 gsr ECU. my question is what do i plug the 4 wire o2 sensor plug into? because the stock 96 ex motor had the o2 sensor on the front of the header but the b18c1 doesnt have one. is the o2 sensor located somewere else or is there not one?
oh yea there is also 1 vacuum hose coming from the cruise control. what do i do with it?
thanx
Modified by vultron at 9:58 AM 4/18/2004
Old Apr 18, 2004 | 05:59 AM
vultron's Avatar
Default Re: b18c1 -> EK o2 sensor question (vultron)
bump
Old Apr 18, 2004 | 01:34 PM
vultron's Avatar
no one can help me?
Old Apr 19, 2004 | 05:07 AM
vultron's Avatar
someone must know
Old Apr 19, 2004 | 07:59 AM
B18C1 '96 Coupe's Avatar
Default Re: (vultron)
You have one at teh end of the header/manifold and one in the cat. you may have to extend your primary to teh end of teh GSR manifold/heder.
Old Apr 19, 2004 | 08:04 AM
vultron's Avatar
Default Re: (B18C1 '96 Coupe)
ok i must be blind. i didnt see one at the end of the manifold/header. i will check again. as for the vacuum hose from the cruise control module do you know anything about that?
thnx
Old Apr 19, 2004 | 08:22 AM
Ummm I cant remember how I got mine to work. Hold On a Sec I took some pics on mine. and how we gotit to work. you have the rubber hoses correct? let me post thiese pics in a sec
Old Apr 19, 2004 | 08:34 AM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vultron &raquo;</TD></TR><TR><TD CLASS="quote">ok i just swapped a 97 b18c1 into my 96 honda EX using the 96 ex wire harness and the 97 gsr ECU. my question is what do i plug the 4 wire o2 sensor plug into? because the stock 96 ex motor had the o2 sensor on the front of the header but the b18c1 doesnt have one. is the o2 sensor located somewere else or is there not one?</TD></TR></TABLE>
The stock GSR manifold doesn't have a spot O2 sensor, it's in the cat. converter (both O2's are for OBD2). You can have a muffler shop drill a hole(s) into your exhaust piping and weld on a threaded nut that the O2 sensor(s) can thread into. You could also get an aftermarket cat with 2 O2 sensor holes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vultron &raquo;</TD></TR><TR><TD CLASS="quote">oh yea there is also 1 vacuum hose coming from the cruise control. what do i do with it?</TD></TR></TABLE>
You can "T" the line into another vacuum line if there is no spot for it or you can also remove the cruise control system completely.
Old Apr 19, 2004 | 08:39 AM
Ok here it goes Kinda hard to see but I hope you can see how it runs.
start from the CC controller
take that vacuum line and follow that
Then go to the very top by the winsheild. and there should be some kinda of connector
Then you should be able to go into the manifold from there. you dont need to use checkvalves taht s all we had liening around so we closed the valves.
I really need to get a longer VAcuum line but I dont tend to care right now becaeu my B18B1 is going in
Old Apr 19, 2004 | 08:46 AM
vultron's Avatar
great pics thnx. that helps alot.
VTECVillain - ok so basically im screwed right now. does OBD1 use 2 O2 sensors? if not i think ill go that route
Old Apr 19, 2004 | 11:37 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vultron &raquo;</TD></TR><TR><TD CLASS="quote">VTECVillain - ok so basically im screwed right now. does OBD1 use 2 O2 sensors? if not i think ill go that route</TD></TR></TABLE>
If you run an OBD1 ECU, you only need to use 1 O2 sensor. It's better for tuning and performance reasons, get yourself and OBD2 to OBD1 ECU adapter harness and an OBD1 P72 ECU.
Old Apr 22, 2004 | 09:22 AM
vultron's Avatar
B18C1 '96 Coupe - i thought i understood what you did but its not really clear in the last pic. do i have to someone connect the vaccum from the CC unit to the intake manifold?
if you have any more pics of the last step that would help alot. thnx.
xci9v8icx
14
Jun 14, 2009 03:58 PM
lazii_boi08
Nov 11, 2008 05:45 PM
sanegb16
Aug 4, 2007 05:06 PM
96teggynonVtec
Mar 23, 2007 06:42 PM
Greasemonkey
Mar 6, 2004 04:57 PM
