b18c dizzy
Old Jun 7, 2013 | 05:09 AM
nanuburnett's Avatar
Default b18c dizzy
hi i have a eg with a b18c droped in and the dixxy (distributor) is going i think its is making barny (my car ) spluter and boping. and i was told its running on 2 cilinders if i get a new dizzy will that fix my problem.
thanks guys
Old Jun 7, 2013 | 05:24 AM
rudebwoy's Avatar
Default Re: b18c dizzy
No!
trouble shoot before you replace parts.
Old Jun 7, 2013 | 05:27 AM
grumblemarc's Avatar
The Grumpiest
How about you check timing before you go replacing parts? When was the last ignition tune up? Is the Check Engine Light on?
Old Jun 7, 2013 | 07:02 AM
S2BumpsticksGSR's Avatar
Exactly- tune up, like grumblemarc said. Auto 101
Old Jun 7, 2013 | 08:13 AM
sleepyaccord96's Avatar
please do not use ghetto slang such as dizzy...who the hell came up with that anyways?!
you need to do a full overall diagnosis of your ignition parts before you start wasting money and throwing parts at the car...
Old Jun 7, 2013 | 08:15 AM
The Grumpiest
Fighting a losing battle with that one.
Old Jun 7, 2013 | 09:26 AM
you're right
Old Jun 7, 2013 | 09:30 AM
Joshka89's Avatar
because "tranny" is so much better haha.
Seriously if you car is running on 2 cylinders you have some severe issues, so I doubt that's actually it.
You need to do the basics:
Spark
Fuel
Air
after you make sure it has those 3 (the triangle of fire) then get to troubleshooting other things.
Old Jun 7, 2013 | 12:40 PM
I've seen quite a few cap/rotors that's been neglected enough to run on only 3 cylinders. A tune up will usually reveal a lot in the process of just pulling the parts, not necessarily replacing them(if not needed) could be quite a few things, you're right. First thing I check is cap/rotor, just sayin only takes a little carbon to be an issue
Sep 21, 2009 07:39 PM
jonyb
Apr 18, 2006 08:28 AM
EG6-SiR
11
Jun 28, 2001 08:35 PM
