B18B into EK...help with drivers side mount
Ok, everywhere I've looked it has said I need the 99SI drivers side mount. First of all, are they talking about the bracket or the engine mount with the studs on it. I noticed along time ago that my stock d-series studs are offset a little, whereas the b18's studs are lined up perfectly and a little closer together (looking from the top)
So I figured I need an SI bracket, so I buy one off ebay. The damn bracket I got is the same as my y-7 bracket, WTF? Either I'm looking for the wrong bracket or what I got wasn't an SI bracket at all.
first the obd2a-obd2b dizzy bull ****, and now this crap.
Can somebody please tell me what the hell I need to be looking for?!?! A pic would be even better.
you need the Si bracket (bolts to the motor and to the rubber chassis mount). the rubber mount with the stud is the same for D and B series. if the bracket you ordered is identical to your D series bracket you may have been ripped off.
I tried to order just the bracket from honda before I bought this one, and they told me I have to order the whole rubber mount and bracket together, which is 80 something dollars.
XkjeldorX
Jun 21, 2006 01:49 PM
