B18a spap in CRX. Getting a code 12 ...
Old Apr 18, 2001 | 12:59 PM
rioninja's Avatar
Default B18a spap in CRX. Getting a code 12 ...
I just put a B18a into my 91 CRX, and i'm getting a code 12. The listing for code 12 is:
12 EGR Lift Sensor (Exhaust Gas Recirculation)
defective circuit or unplugged / defective sensor
* not a valid code if car is not equipped with an EGR valve (some Civic models are not)
I used the original CRXsi wiring harness. Is is possible that i have a bad sensor, or is it the wiring? Thanx
Old Apr 18, 2001 | 01:28 PM
Cory man's Avatar
Default Re: B18a spap in CRX. Getting a code 12 ... (RioNinja)
possibly a bad sensor, check all your connections just to make sure they are all plugged in correctly. If you have an integra helms you can trouble shoot the prob with a volt meter. If all checks out and still a code try the junkyard for the part. Remember to reset the ecu each time you change anything. hth
Bense
Jun 8, 2007 03:39 PM
technine
Apr 18, 2007 10:51 AM
Stevegunit16
Feb 14, 2007 09:14 AM
accord0494
Mar 4, 2005 04:47 PM
FURACERMAN
Dec 1, 2003 06:40 AM
