b18 vs. b20?..
Old Jul 21, 2002 | 02:02 AM
baybeboi's Avatar
Default b18 vs. b20?..
Is the b20 really worth it, over a b18?.. I know it has more torque.. but not as much. Isn't the b18 in terms of torque.. 128tq.. and the b20b a little more than that.. 130ish maybe? I might plan on going turbo and was wondering what would be better.. b18 or b20?
Old Jul 21, 2002 | 06:49 AM
Spade's Avatar
Default Re: b18 vs. b20?.. (baybeboi)
B20 hands down.
Different and beefer sleeves. Larger bore and I don't remember the exact Ft-lbs number however, every little bit makes a difference.
Old Jul 21, 2002 | 11:03 AM
dohcsideSi's Avatar
Default Re: b18 vs. b20?.. (Spade)
B20 hands down.
esp stock vs stock....every little bit does count!!
Old Jul 21, 2002 | 11:57 AM
baybeboi's Avatar
Which would be better for turbo?.. 9psi?
Old Jul 22, 2002 | 10:24 AM
Spade's Avatar
see above
Old Jul 22, 2002 | 10:54 AM
Dokta's Avatar
Both would need new rods for turbo. Actually the piston to rod pin is the limiting factor.
Old Jul 22, 2002 | 11:20 AM
Charlie Moua's Avatar
I would go B20, stronger block. the rods can take about 8-9psi, and can be reved to 8500 but reving that high woth stock rods is sorta risky.
B20 all the way
Old Jul 22, 2002 | 12:02 PM
blufke's Avatar
Default Re: b18 vs. b20?.. (Charlie)
b20 is great for turbo. im getting my b20 soon,hopefully. read around, youll see some people making 160hp/145ft/lb at the flywheel w/I/h/e. good hp and fantastic tq.
Old Jul 22, 2002 | 09:51 PM
baybeboi's Avatar
I know this is off the subject but to boost a b20 up to 9psi or around that.. You would need at least just pistons and rods correct?.. good tuning n all that also. What kind of pistons and what kind of rods? Thanks.
Old Jul 22, 2002 | 10:12 PM
lazy bum shaughn's Avatar
For 9 psi stock internals are just fine. You can even boost higher as long as you alter the fuel settings and get larger injectors. JE makes good pistons and Crower and Eagle make good rods.
Old Jul 22, 2002 | 10:57 PM
tinkerbell's Avatar
Default Re: b18 vs. b20?.. (Mixxed Bboy)
have you tried this?
how long did it last for,
what numbers?
t..
Old Jul 24, 2002 | 09:49 AM
RevinRex's Avatar
Default Re: b18 vs. b20?.. (tinkerbell)
Would a B20/Vtec be good at 9psi with proper tuning?
Old Aug 4, 2002 | 08:25 PM
Default Re: b18 vs. b20?.. (YBLegal)
Anything would handle 9 psi with PROPER tuning. Just have to know what you're doing.
Old Aug 4, 2002 | 09:12 PM
racecarpete's Avatar
this is kinda off-topic but at what psi would you consider resleeving? thanks.
Old Aug 4, 2002 | 09:19 PM
Kamin's Avatar
Default Re: b18 vs. b20?.. (SilverCivic2k)
9 on a regular basis i would resleeve
or get a block guard.
Lost H
Jul 12, 2008 03:39 PM
SinsEvil666
Jan 28, 2008 08:57 AM
l3owen
Feb 7, 2004 08:17 AM
russian_racer
16
May 13, 2003 11:51 PM
mi2lo4u
Nov 15, 2002 07:42 AM
