B16a2 in 99 ex?
Old Jan 25, 2006 | 07:25 AM
Claybob86's Avatar
Default B16a2 in 99 ex?
I had a 95 civic with a turbo'd b16 in it, but sadly, i totaled it what all would i need if i wanted to put this swap into a 99 ex?
Old Jan 25, 2006 | 03:44 PM
v-tec maz's Avatar
Default Re: B16a2 in 99 ex? (Claybob86)
what year b16 is it? if its 97+ then its an obd2 and you dont need any thing other than the custome mounts and axles that you prolly got
Old Jan 25, 2006 | 04:18 PM
Claybob86's Avatar
Default Re: B16a2 in 99 ex? (v-tec maz)
its out of a 95 SiRII so its obd1
Old Jan 25, 2006 | 10:12 PM
Katman's Avatar
you'll need to convert your OBD1 B16 to OBD2 spec in order to make it compatible with a 99 EX by changing these items:
- injectors & engine wire harness
These things can actually be reused from your EX engine. BTW, the EX injectors are the same PSI as your OBD1 B16A injectors.
- alternator
you'll need to rewire the OBD1 alternator to work with the EX engine harness, or you can sell/trade the OBD1 alt. for an OBD2 B-series alt. which would then be a plug n play dealy.
- ECU
You'll need an OBD2b-OBD1 jumper harness in order to reuse the OBD1 B16A ecu.
- Axles & Shift Linkage
You can reuse these parts from your B16 on the 99 EX....fully compatible
- Motor mounts
you'll need to reuse your EX's TOP tranny mount which is compatible with a B-series tranny. And reuse your existing timing belt side mount + 'bridge' bracket.
You'll need to get yourself these mounts from either a 94-01 integra (any model) or 99-00 Si:
- Front tranny bracket
- A/C bracket
- Rear engine bracket (get this from a 99-00 Si)
- Additional Wiring
you won't need to do any additional wiring since you own an EX. All VTEC, knock sensor, and IACV wiring is already done from the factory. You may need to extend some wiring though....
That should be it...
krysted9354
Apr 9, 2009 06:59 AM
DetainedCivic
Apr 17, 2006 10:52 AM
