Throwing code 16 HELP!
Old Apr 12, 2005 | 09:00 AM
Ekay Jay's Avatar
Default Throwing code 16 HELP!
The other day my car broke down and the check engine light came on. Used the paper clip ta check what code i was throwing and it was 16-fuel injectors. So the car isnt getting any fuel, sprayed starting fluid in the intake and it started. So what can be the problem? Why is it not getting any fuel? Fuse maybe? Thx for ur help!
Old Apr 12, 2005 | 09:03 AM
LShatchie's Avatar
Default Re: Throwing code 16 HELP! (JdM DA InTeGrA)
Maybe your injectors are a bit clogged, or your fuel filter.
Old Apr 12, 2005 | 10:25 AM
Ekay Jay's Avatar
Default Re: Throwing code 16 HELP! (LShatchie)
Now throwing code 14 also-Electronic Air Control......
Old Apr 12, 2005 | 11:12 AM
EFz6er's Avatar
I have both those codes as well on my LS hatch. I installing a new set of injectors, new fuel filter, new plugs and wires. That will hopefully get rid of the code 16.
What is the car doing? Does it run? Idle? Anything different with the exhaust?
My car will be complety fine one minute.....then it will bog, white smoke pours out of the tailpipe with a super strong gas smell and sometimes there will actually be unburnt fuel dripping out. Sometimes I will simply just turn the car off and back on and it will be fine. And then it all happens again. I think I have a clogged injector, that uncloggs and re-cloggs itself the gets stuck open blah blah blah
I have no clue about the code 14. I have cleaned my IACV and exchanged it for a know working one and I still get that damn code. Oh well, now Im concentrating on the code 16.
Old Apr 12, 2005 | 11:33 AM
Ekay Jay's Avatar
Default Re: Throwing code 16 HELP! (EFz6er)
The car wont start at all. I was driving it and it just quit. I checked the fuel line tha goes to the fuel rail and it had fuel in it. As for the cel 14, i fixed that.
Old Apr 12, 2005 | 12:17 PM
EFz6er's Avatar
what fixed code 14
Old Apr 12, 2005 | 12:48 PM
Ekay Jay's Avatar
Plug was loose.
Old Apr 13, 2005 | 04:36 AM
Ekay Jay's Avatar
UPDATE- Checked the fuel line ta see if it had fuel in it. Im getting fuel to the fuel rail and to the injectors. Also checked the voltage, im getting power to the injectors. Wtf is the problem?
Old Apr 13, 2005 | 05:24 AM
Ekay Jay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LShatchie &raquo;</TD></TR><TR><TD CLASS="quote">Maybe your injectors are a bit clogged, or your fuel filter. </TD></TR></TABLE>
Yes but i find it very unlikely that all 4 injectors got cloged at the same time. Somone help
Old Apr 13, 2005 | 02:00 PM
Ekay Jay's Avatar
Just changed out my injectors and that didnt do ****.....
Old Apr 13, 2005 | 03:20 PM
Ekay Jay's Avatar
anyone?
Old Apr 13, 2005 | 04:05 PM
Ekay Jay's Avatar
Old Apr 13, 2005 | 11:44 PM
327da9's Avatar
Have you checked your resistor box, or the resistance of the resistors to see if one of them is fried.
I assume your car is obd-0?
Old Apr 14, 2005 | 11:57 AM
Ekay Jay's Avatar
Default Re: Throwing code 16 HELP! (327da9)
its obd-1, just put some different injectors in and it still didnt do anything.
Old Apr 14, 2005 | 01:29 PM
boosted k20's Avatar
unplug the connectors to the injectors and plug them back in. u may have a bad contact somewhere in the injector plugs
Old Apr 14, 2005 | 06:30 PM
Ekay Jay's Avatar
Default Re: Throwing code 16 HELP! (boosted k20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 &raquo;</TD></TR><TR><TD CLASS="quote">unplug the connectors to the injectors and plug them back in. u may have a bad contact somewhere in the injector plugs</TD></TR></TABLE>
Iv already done that about 50 times already, I cleaned out all my plugs.
sho_shane
Mar 24, 2010 04:56 AM
TheCheeseWedge
Jun 3, 2007 10:48 PM
maxboost_50psi
Feb 11, 2007 08:18 PM
raiden571
May 18, 2005 10:54 AM
adeline
Apr 11, 2005 07:13 PM
