b16 vtec engagement point?
Old Aug 19, 2003 | 03:13 AM
yellowmonkeyboy's Avatar
Default b16 vtec engagement point?
just did b16 swap into eg hatch
just wondering where the vtec engagement point is?
i tried searching no luck
Old Aug 19, 2003 | 07:37 AM
EF_LSVtec's Avatar
Default Re: b16 vtec engagement point? (yellowmonkeyboy)
what ecu are u running?
Old Aug 19, 2003 | 04:27 PM
Audi RS4's Avatar
Lover
isn't it 5800 stock?
Old Aug 19, 2003 | 04:36 PM
Patch's Avatar
Default Re: b16 vtec engagement point? (AK1200)
PR3/PW0 is 4800.
All other B16s are 5200, with the exception of the B16B.
Old Aug 20, 2003 | 08:03 PM
Default Re: b16 vtec engagement point? (CRX PAT)
hmm i have a b16a2 jdm ,,, it seems like it is kicking in around 5800-6000
Old Aug 21, 2003 | 04:00 PM
drvfast's Avatar
it should be 5200 with the jdm p30. i have a jdm b16 sir2 also and on my tach it seems to kick in around 5800-6000 but i think the tach is inacurate.
Old Aug 24, 2003 | 03:23 AM
nominous's Avatar
PW0-E00 (EDM ECU) is 5280 under WOT
PW0-000 (JDM ECU) is 4800 under WOT
It will enage higher under less load.
Modified by nominous at 2:15 PM 8/24/2003
Old Aug 25, 2003 | 04:43 PM
Default Re: (nominous)
hmm. well ill go switch out my ecu and check it out to see if it will engage earlier
Old Aug 25, 2003 | 08:33 PM
b16adx's Avatar
Stock engagement on the p30 and the civic Si ecu is 5500 all day everyday
Old Aug 26, 2003 | 08:25 AM
92b16vx's Avatar
Default Re: (b16adx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16adx &raquo;</TD></TR><TR><TD CLASS="quote">Stock engagement on the p30 and the civic Si ecu is 5500 all day everyday</TD></TR></TABLE>
That when my P30 kicks in, but when I hooked up my VAFC, it was defaulted to 5800.
Old Aug 26, 2003 | 07:32 PM
Default Re: (92b16vx)
are you guys sure mine is kicking in around 5800-6000.. def not 5500 and its a p30 ecu
Old Aug 26, 2003 | 08:58 PM
b16adx's Avatar
well maybe your tach is off b/c my p30 def. kicks in at 5500 and the other p30's ive used
Old Aug 26, 2003 | 11:16 PM
Lysawy's Avatar
5800 here and the redline should be 8200rpm and the funny thing is i never got to the point when my needle was suppose to be jumping around my tach, can it be way off but when i checked it was only off by 120ish rpm or so... gotta get a dyno to finally find out whats going on...
VRD^sam
Apr 11, 2005 10:45 AM
davidcrx89
15
Feb 17, 2005 09:55 PM
JHD_DA
Dec 28, 2003 05:54 AM
