B16 early vtec
B16 early vtec
my vtec on my b16 in my 91 crx comes on at about 4500 rpms and rev limites at about 7800 im a little curious about the vtec coming on so early does any one know why and if its good or bad
thanks in advance
thanks in advance
Re: B16 early vtec (davidcrx89)
my b16 was right on with the tach until the last few months i had it... the tach was reading exactly like you described it... i didn't really have an answer why but i believed the tach was off all of a sudden... if you have a friend who has an aftermarket tach you can borrow, try that, other than that i don't know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davidcrx89 »</TD></TR><TR><TD CLASS="quote">calm down</TD></TR></TABLE>
ha ha... you tell 'em, noob!
Re: B16 early vtec (HamiltonRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex »</TD></TR><TR><TD CLASS="quote">omg search.. i just replied to a similar post 5min ago!!</TD></TR></TABLE>
So did i.....https://honda-tech.com/zerothread?id=1151991
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davidcrx89 »</TD></TR><TR><TD CLASS="quote">I have a question i just installed my B16 in my 91 CRX HF and it seems to hit the rev limiter at about 7800 RPM's and my friends cars hit at 8200 is this just a wierd difference in ECU's or is somthing wrong.</TD></TR></TABLE>
And my reply
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hahagasdcrx »</TD></TR><TR><TD CLASS="quote">swap ecu's with your friend and see if it still does it. More than likely your tach may be a little off.</TD></TR></TABLE>
davidcrx89..... you need to check up on post you've already made, not start a new thread about the same thing.
And my reply
Re: B16 early vtec (hahagasdcrx)
i did check them and they dont match!!! or answer my question so i guess what im saying is if your not going to help than DON'T REPLY!!!!!.
but thanks to those who were lots of help.
so i checked my ecu to see if its an auto as mentioned and its not also it is a PR3 ecu OBD0 and it is throwing a coolant tempature code and i double checked all the wires and the seemed to all be pluged in correctly
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davidcrx89 »</TD></TR><TR><TD CLASS="quote">it is throwing a coolant tempature code and i double checked all the wires and the seemed to all be pluged in correctly</TD></TR></TABLE>
okay... now check resistance and voltage
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davidcrx89 »</TD></TR><TR><TD CLASS="quote">on the tempature sensor ?</TD></TR></TABLE>
yep
yep
