b16 swap help!
Old Oct 15, 2004 | 06:47 AM
slimcivic95's Avatar
Default b16 swap help!
my friend swapped a b16 second gen into his 95 ex just like mine it starts,idles,and heats and cools fine. The check engine lights on and it runs sluggish and wont rev past 5,500 on the p30 ecu. When i put my chipped p28 in, it throws a check engine light but it revs past 5,500. Could his ecu be bad or is something just wired wrong that my p28 doesnt pickup.
Old Oct 15, 2004 | 07:56 AM
deSigi's Avatar
You should definitely jump the service connector to find out which code is being thrown. It might be easier to judge what is the cause at that point.
Old Oct 15, 2004 | 08:09 AM
Slopoke's Avatar
Default Re: (deSigi)
Check the code first.
Old Oct 15, 2004 | 09:53 AM
mental1's Avatar
Did he add the wire for the knock sensor, cause your p28 won't catch that. But, the p30 will. Also check the code to make trouble shooting easier.
Old Oct 17, 2004 | 06:18 AM
97mini-me's Avatar
Default Re: b16 swap help! (slimcivic95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mental1 &raquo;</TD></TR><TR><TD CLASS="quote">Did he add the wire for the knock sensor, cause your p28 won't catch that. But, the p30 will. Also check the code to make trouble shooting easier.</TD></TR></TABLE>
It will feel sluggish if this is the case. I didn't have my knock sensor hooked up on my obdII mini me and it would rev to the rev limiter, but vtec wouldn't kick in. Once it was hooked up it ran better. CHECK THOSE CODES!
cadwiese
12
Dec 6, 2008 02:00 PM
arielmalespin
May 31, 2005 03:45 PM
CR_VtecCRX89
15
May 19, 2005 07:17 PM
enigma94
Sep 17, 2004 08:59 PM
playAho
12
Mar 29, 2003 05:37 PM
