b16 linkage?
Old 08-27-2006, 11:09 AM
mythos666's Avatar
Default b16 linkage?
hi guys. im doing a b16 sir gen 2 swap into my 93 civic lx sedan. trying to hook up the shift linkage and for some reason its too short. i got the shift linkage with the swap so i assume its b16 linkage. is this linkage supposed to work or do i still need hasport or integra 94 + linkage? thanks. also, is avid linkage any good?
Old 08-27-2006, 11:18 AM
spoonracer84eg's Avatar
Default Re: b16 linkage? (mythos666)
The shift linkage I got fit my eg hatch. I am not sure that it would fit your sedan though. The sedan is longer which would explain why its too short. Im not sure that the 94+ integra linkage will work either. Ill try to find you an answere.
Old 08-27-2006, 11:27 AM
From what I was able to find the 94+ integra linkage will work. They might have sent you the wrong shift linkage. If you can take a pic of it and I will tell you if it looks right or not. They usually also mark on the shift linkage what its for. See if you can find anything.
Old 08-27-2006, 11:31 AM
mythos666's Avatar
Default Re: b16 linkage? (spoonracer84eg)
thanks man.
ill take a pic tomorrow as i cant today. ill also look for markings.
both rods on the linkage are almost the same length as well.
i can get the shift rod on the tranny but doesnt shift right (too tight)
and the other rod kinda looks like this: (this isnt an actually pic of my car)
http://hondaswap.com/attachmen...8.jpg
its about 6" or so away from attachment point.
thanks.
Old 08-27-2006, 11:54 AM
Thats a d series linkage on top. The lower one looks b series. Once its on is it too tight to drive. Mine is not the best either but it works.
efhatch1991
06-29-2013 10:41 AM
Its me DUB
03-02-2007 08:42 AM
onefastx
10-26-2006 05:41 AM
0utaSight
10-16-2003 11:12 PM
egciviccx
03-17-2003 09:48 AM
Quick Reply: b16 linkage?
