B16 A1 vs B16A2
Old Aug 27, 2002 | 09:46 PM
DMF's Avatar
DMF
Default B16 A1 vs B16A2
What is the difference between a B16a1 and the B16a2? I believe that they are basically the same. Is this correct? What car is the B16A1 out of?
Old Aug 27, 2002 | 10:21 PM
Kamin's Avatar
Default Re: B16 A1 vs B16A2 (DMF)
*sigh*
https://honda-tech.com/zerosearch
here.
b16a1 - OBD0 , if your car is 92 or newer DO NOT BUY A FIRST GEN B16. i repeat DO <FONT COLOR="RED">NOT</FONT> BUY A FIRST GEN B16
it will cost you about as much as a second gen swap to do it
and it has a weaker set of cams.
diffrences= transmission, clutch, dist, injectors, wiring harness, cams, etc.
[Modified by KAMiN, 11:22 PM 8/27/2002]
Old Aug 27, 2002 | 11:34 PM
raene's Avatar
Default Re: B16 A1 vs B16A2 (KAMiN)
Oiling system's different too isn't it?
Old Aug 28, 2002 | 07:35 AM
B16A1-EF9's Avatar
Default Re: B16 A1 vs B16A2 (raene)
Check this out:
http://www.profxtech.com/illuzion/fo...43&threadid=42
EBPCoupe_Si
Jun 9, 2006 05:26 PM
95cxhatch
Jan 29, 2005 01:29 PM
dohcMONSTER
Nov 25, 2003 04:38 PM
S
Oct 28, 2002 10:07 PM
Altered_Ego
Apr 29, 2002 10:17 AM
