b series trans
Old Feb 22, 2003 | 10:39 AM
civic_non_vtec's Avatar
Default b series trans
i have 95 integra b18b, im putting in a 00 civic trans. what do i all have to chang?????
Old Feb 25, 2003 | 02:05 PM
sleedawg's Avatar
Default Re: b series trans (civic_non_vtec)
nothing... all the sensors are the same. where are you located? wanna sell that old LS tranny?
Old Feb 28, 2003 | 09:19 PM
project92hb's Avatar
Default Re: b series trans (sleedawg)
i doing the other way b16a with ls tranny. does any one know what shiftlinkage i needand what ecu i can use
Old Feb 28, 2003 | 10:28 PM
Kamin's Avatar
Default Re: b series trans (project92hb)
why are you running an ls tranny with a b16?
thats gonna completley kill what very little power the b16 makes
the reason the b16 makes it as a good engine is because of the short *** gear ratio.
the ls tranny will kill it.
even with boost it would be too long unless your running 20+ psi and pushing 400hp.
all the stuff will switch over, you dont need any diffrent ecu linkage sensor etc.
and civic_non_vtec if you mean put a SOHC civic transmission on a b18b block, it wont work.
[Modified by Kamin, 11:29 PM 2/28/2003]
Xathine
May 13, 2009 07:51 PM
bomp drop
Sep 7, 2006 03:15 PM
civicdust
10
May 22, 2005 12:08 PM
gribbs
Apr 13, 2003 11:14 AM
