B-series Brackets?
Old Nov 11, 2002 | 04:29 PM
2muchPSI's Avatar
Default B-series Brackets?
Hey,
I have been told i need a bracket for the driver side and rear motor mounts for putting a b series engine into a EG hatchback. I am confused as to what these parts are. Can i get them off of an integra or civic like i can the motor mounts?
Thanks for all your help guys.
Old Nov 11, 2002 | 04:43 PM
poison's Avatar
Default Re: B-series Brackets? (92tealvx)
which B16 are you looking at installing?
Old Nov 11, 2002 | 05:58 PM
Kataku2K3's Avatar
Default Re: B-series Brackets? (poison)
If your EG is a 95 Si then you can use the driver side upper motor mount.... You will have to get the motor mount that bolts to the block from a 94-2000 Integra or a Delsol's.. **** that's sad but i don't even know the exact year for Delsol's.. Oh well I don't like em anyways.. Peace
Old Nov 12, 2002 | 03:24 PM
2muchPSI's Avatar
Default Re: B-series Brackets? (JDMspecEG6)
I will be putting a b17 into a 92 vx, so therefore i need the bracket from the 94-00 integras for the drivers side, what about the rear bracket?
Old Nov 12, 2002 | 04:45 PM
Kataku2K3's Avatar
94-2000 Integra...Delsol.. Just not 99-2000 Si
Old Nov 12, 2002 | 05:40 PM
Katman's Avatar
ok, if your B17A has a 2-post mount (as seen in pic) then you can you reuse your VX's timing belt side mount. Most of the time, the 3-post mounts are only found on B18C engines, which need that unique aluminum liquid filled 3-post motor mount:
Top tranny mount -- you can also reuse your VX's TOP tranny mount as well.
Front tranny mount -- you'll have to get one from a 94-01 integra, 99+ Si coupe, or DOHC DELSOL.
Rear bracket from a 94-01 Integra (like JDMspecEG6 said).
Here's some additiona (and repetative) info on motor mounts needed for your swap:
[Modified by Katman, 6:40 PM 11/12/2002]
[Modified by Katman, 6:43 PM 11/12/2002]
Old Nov 13, 2002 | 12:24 PM
2muchPSI's Avatar
Default Re: B-series Brackets? (Katman)
katman, thank you soo much, you are the first person to actually give me some good info, i appreciate it
asocallocal
Apr 11, 2008 10:28 PM
2004es2
58
Jan 17, 2008 11:46 PM
Hatchd
Jun 22, 2005 04:00 PM
turbo_civic005
Sep 11, 2004 09:17 AM
