Axles binding ? (H22A in Integra)
Old Jun 4, 2004 | 11:45 AM
simon98h22's Avatar
Default Axles binding ? (H22A in Integra)
I have an H22A into a 98 Teg, we used the 95 Lude mid shaft (came with motor) and the stock teg 98 axles. We got a set of 90-93 teg axles and could not see any diff between the 90-93 and the 98 axles. Motor is installed but now when veering left in a slalom kinda pattern, I'm getting a serious vibration, only when veering left, right is fine. I used HCP mounts for the setup. I've never heard an axle binding so I'm not sure if that's it. It's not clicking, like a soft thump vibrating that you can really notice. Is there a actual difference between the 90-93 and 98 ones? Does this sound like binding? Any and all info very appreciated. (My car is on Eibach springs - 1.3" drop)
So close .... this is my last piece of troubleshooting
Simon
Modified by simon98h22 at 9:00 PM 6/4/2004
Modified by simon98h22 at 6:55 PM 6/7/2004
Old Jun 5, 2004 | 06:33 PM
simon98h22's Avatar
Default Re: Axles binding ? (simon98h22)
Update, it says on the HCP site to use a 94+ oem half shafts and to modify the passenger side one by replacing the inner joint with a 92+ lude one, I did that today and still have the problem. It's an H22A with LSD. Anyone ?
Old Jun 8, 2004 | 09:22 PM
cpforyou's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simon98h22 &raquo;</TD></TR><TR><TD CLASS="quote">Update, it says on the HCP site to use a 94+ oem half shafts and to modify the passenger side one by replacing the inner joint with a 92+ lude one, I did that today and still have the problem. It's an H22A with LSD. Anyone ? </TD></TR></TABLE>
Welcome to the club. I have a 92-95 Honda Civic. I never had any problems. As soon as I switched to an OEM LSD Transmission, I have the same problem as you.
Sivik
May 18, 2005 07:11 AM
simon98h22
Feb 17, 2005 05:44 AM
RedK
May 29, 2004 11:36 AM
User 5426
Oct 8, 2003 05:57 PM
redstorm82
Dec 23, 2001 01:46 PM
