GSR EG Idle has mind of it's own! (Crazy Fluctuation)
Finally got my GSR Swapped EG to fire up, fires up perfectly, but here's my problem. Immediately after the car turns over, engine revs it self.... all the way up to 5-8k rpm (Sometimes even 9) and fluctuates in between there. I did my vacuum lines accordingly, but i am missing the IAB check valve and I also still need to wire up my EVAP Purge Solenoid plug because I'm using a z6 harness, but still the idle shouldn't be this crazy with out those things right? Tips, suggestions , tech help greatly appreciated.
Re: GSR EG Idle has mind of it's own! (Crazy Fluctuation)
You must have a MAJOR vac leak some where the iab not wired up doesn't matter neither does the evap(as long as the line are capped) put you'r hand over the throttle body i most likly won't die listin for leaks when you do that. but first vissualy inspect that all lines are plugged in/snug
what happens when you put you'r hand over the trottle body does it die
Fit could be it. It's on n the bottom of the tb. I had an issue just like yours, removed the fit valve, and viola! Gone. It's super easy, and worth a shot. Free as well.
Car doesn't die when I put my hand over the TB and cable is fine.
autoxthis
02-12-2004 09:17 PM
