Another Idle question
Old Sep 18, 2012 | 11:21 AM
daytonagp4's Avatar
Default Another Idle question
I recently put a eBay knock off junk 2 intake manifold on my b18c1. The car ran fine before I changed anything but now all I did was the intake swap and it runs weird. I haven't taken it down the road yet but at an idle it seems like its got a set of huge nasty cams in it. Bounces between 900 and 1400 about twice a second. Like a huge cam loping. I checked all the wiring it's correct and the only other thing I could think of is the map or iac is going ....any other suggestions??
Old Sep 18, 2012 | 11:44 AM
kyden's Avatar
Default Re: Another Idle question
do you have any vacuum leaks? spray carb cleaner and see if the idle stabilizes.
Old Sep 18, 2012 | 11:54 AM
daytonagp4's Avatar
Did that.....no variation at at
Old Sep 19, 2012 | 07:34 AM
daytonagp4's Avatar
Cleaned iacv still does it. Test drive later today
Old Sep 19, 2012 | 08:06 AM
kyden's Avatar
are you using the correct tb gasket?
Old Sep 19, 2012 | 01:06 PM
daytonagp4's Avatar
Yeah stock one I assume is right
Old Sep 19, 2012 | 01:07 PM
daytonagp4's Avatar
Also running very very rich
Old Sep 22, 2012 | 12:18 PM
daytonagp4's Avatar
CLICK ME^^^^^^^ PLZ TURN YOUR VOLUME DOWN IT'S LOUD!!!!!!
Help me plz!! Do i need a new map or what do i need? I put the old intake back on and it ran fine. Put this one on and runs like shiznit and i need to figure it out ASAP. Any help would be great, no vac leaks at all either.
Old Sep 24, 2012 | 04:23 AM
daytonagp4's Avatar
bump for vid?
89CivicHb1
Jan 4, 2009 11:00 AM
FloGgY
Apr 12, 2008 01:13 PM
byronl
Dec 20, 2006 05:29 AM
crexer
20
Mar 13, 2005 01:35 PM
dustinsterk
Dec 31, 2003 04:10 AM
