Adding coolant after the swap
Old Jan 10, 2009 | 04:18 PM
richiejr416's Avatar
Default Adding coolant after the swap
How should i add the coolant after the swap, or more specifically get the air out once i add the coolant? In my service manual it explains how to do it using a bleed bolt, but I don't have a bleed bolt on my engine... Anyone have a general procedure in mind? Any input is appreciated
Old Jan 11, 2009 | 06:01 AM
LA_HONDAS's Avatar
Default Re: Adding coolant after the swap
jack the front of car up as high as you can then put the coolant in until its full then start the car up then rev it up and down (from idle to about 3000 rpm's) by the TB add coolant if need it then put the rad.. cap on and let car down then open the bleeder valve to let any air out then go around the block a few times then open the bleeder valve to make sure all of the air is out and your done
never had problem with over heating doing it this way
hope this helps
Old Jan 12, 2009 | 07:13 AM
Andres-eh2's Avatar
I usually top off the coolant, put a towel over the radiator, turn the car on, remove the towel and let it idle for about 5 minutes. you should see bubbles coming out.
Old Jan 13, 2009 | 01:50 PM
cockerkid008's Avatar
X2 thats what I do and make sure you turn your heater controls to full heat
hondachris1994
Mar 21, 2006 11:13 PM
HUBB
Jun 4, 2004 11:00 AM
mz3bo
Feb 18, 2003 02:02 PM
drumsy
Sep 12, 2002 06:46 AM
BluLuder
Dec 19, 2001 04:46 PM
