97 integra cluster in ef
Here's the Integra gauge cluster pinouts. Don't forget to use an elcetronic VSS on the tranny or the speedo won't work and you'll get a CEL and run in safe mode.
Integra Left Side Plug (13 pins)
1. BLU - Tach signal
2. GRN/ORG - Check engine indicator
3. YEL/RED - Oil pressure switch
4. -
5. WHT/BLU - Charge indicator
6. -
7. YEL/GRN - Coolant temp
8. BLK - Ground
9. RED/BLU - Cruise control (if you have cruise)
10. YEL - Hot
11. -
12. PINK - Maintenance (not used)
13. -
Integra Right Side Plug (16 pins)
1. GRN/RED - E-Brake signal
2. RED/GRN - High beam
3. GRN/YEL - Right turn
4. GRN/BLU - Left turn
5. -
6. BLK/YEL - Power
7. RED/BLK - Power
8. RED - Power
9. BLU/RED - ABS (not used)
10. GRN - Trunk switch
11. ORG - Vehicle speed sensor
12. -
13. BLU/WHT - Low fuel (only if you have SiR or older Teg fuel pump housing)
14. YEL/WHT - Fuel gauge
15. LGT. GRN/RED - Door switch (not used)
16. RED/BLU - Seat belt
4. -
6. -
8. BLK - Ground
10. YEL - Hot
11. -
13. -
5. -
6. BLK/YEL - Power
7. RED/BLK - Power
8. RED - Power
12. -
lsismore
Jan 13, 2006 01:14 AM
The G2 Racer
Oct 18, 2002 02:38 PM
